Steering damper
- DVs-Jimny
12 Oct 2011 17:48 #23554
by DVs-Jimny
Steering damper was created by DVs-Jimny
I purchased the budget bracket from the BigJimny shop and got a fantastic service as usual, also got an Armstrong LR damper.
Now I have a little bit of confusion and could do with some assistance.
1. Do I turn the wheel to full lock and fully extend the damper and then tighten up the bracket??
2. Does it matter what way round the BigJimny bracket goes?
IE
or
Thanks in advance
PS Actually wired up the roof lights today
IE
or
Thanks in advance
12 Oct 2011 17:57 #23557
Replied by mlines on topic Steering damper
I did it the other way around, turn the steering to fully compress the damper, then expand it slightly and clamp. This avoids it hitting the end stop of the damper.
The bracket goes either way around depending on the damper you have and the clamping position on the arm.
-- Sent from my HP TouchPad using Communities
The following user(s) said Thank You: DVs-Jimny
- DVs-Jimny
12 Oct 2011 18:04 #23558
by DVs-Jimny
Replied by DVs-Jimny on topic Re: Steering damper
Cheers Martin, much appreciated.
- Back in Black
12 Oct 2011 18:12 #23560
by Back in Black
Replied by Back in Black on topic Re: Steering damper
Hi. I got that bracket / damper combo.
I put the steering straight ahead, worked out the length of the damper at the middle of it's travel and set it in that position (old maths teacher would be proud of me) and then (having enlarged the hole in the towing bracket) offered up the shocker and worked out where the bracket should be. Attached if all finger tight and then turned to one lock and checked, then the other lock and checked. Quick tightening of all the nuts and bolts and one test drive later, well pleased. The damper and steering working a treat - no more unexpected lane changing
it even survived Wagtail!!
I hope this helps! It's worked for me. there is no fouling anyway.
With 225/75/15 ats it's made a massive difference - 225/75 MTs calmed a lot but my forearms need a work out.
- vitara_mad
12 Oct 2011 19:07 #23566
by vitara_mad
Replied by vitara_mad on topic Re: Steering damper
i also did mine with the steering straight & measured the damper to find the center position then fitted it & did same on my bro's both worked out fine
- Jjbradshaw1
03 Oct 2018 19:04 #196479
by Jjbradshaw1
Replied by Jjbradshaw1 on topic Steering damper
Do steering dampers help if you’ve put larger wheels and tyres on? Recently put 235/75 ATs on 8j steel rims and they’re trying to pull me into hedges with every bump in the road
Time to create page: 0.099 seconds
