Bugger...
- viciouspenguin
08 Oct 2011 13:40 #23257
by viciouspenguin
Bugger... was created by viciouspenguin
I went to remove the propshaft today as the axle-end UJ needs replacing. While undoing the bolts there seemed to be an excessive amount of movement from the (sj) transfer case. On closer inspection the four bolts nearest the chassis rail (offside) were loose. Tightening them up seemed to do little to two of them. I can only presume that the threads have failed.
Is there going to be enough room to tap a new thread, and secondly who does cheap bucket mounts that will fit the SJ t-case to a jimny?
- darthloachie
08 Oct 2011 15:47 #23260
by darthloachie
Replied by darthloachie on topic Re: Bugger...
sounds like the same problem as we've got
its going into a 4x4 specialist on Tuesday and I'll let you know what they come up with
- viciouspenguin
08 Oct 2011 16:43 #23263
by viciouspenguin
Replied by viciouspenguin on topic Re: Bugger...
the best idea i can think of is getting it re-threaded, with a larger sized bolt. the other option is to replace the case, but that a last resort.
- Gromit
08 Oct 2011 17:02 #23265
by Gromit
Replied by Gromit on topic Re: Bugger...
You should be able to get it helicoiled with a new thread.
- darthloachie
08 Oct 2011 17:21 #23267
by darthloachie
- viciouspenguin
08 Oct 2011 17:42 #23270
by viciouspenguin
they look clever, anyone know the bolt size on the tcase?
darthloachie wrote: are these they?
www.machinemart.co.uk/shop/search/filter.../shopcategory/page/1
