Noice at back diff when excelaration only
  • vitara_mad
07 Oct 2011 07:15 #23196 by vitara_mad
Replied by vitara_mad on topic Re: Noice at back diff when excelaration only
DarrenH 4X4 wrote: it only make a clank noise when you change gears and excelerate.
check gearbox & transfer box mounts as well as everything else thats already been sugested
  • DarrenH 4X4
11 Oct 2011 05:14 #23467 by DarrenH 4X4
Replied by DarrenH 4X4 on topic Re: Noice at back diff when excelaration only
ok i have narrowed it doe n to some thing on the right rear side of the car, it sounds like it is coming from the break area, it is not the dif as i have checked it and replaced the oil, so that is all fine. any help would be appricaited, i am a novice at this so ifo & photos will help, thanks.
  • DarrenH 4X4
11 Oct 2011 05:16 #23468 by DarrenH 4X4
what is a UJ?
  • adamatdraycott
11 Oct 2011 07:25 - 11 Oct 2011 07:29 #23469 by adamatdraycott
Replied by adamatdraycott on topic Re: Noice at back diff when excelaration only
UJ = Universal Joint
Joint or coupling in the end of the drive shaft that allows the shaft to 'bend' in any direction. It consists of a pair of hinges located close together, oriented at 90° to each other.
It sounds to me asthough your joint at the rear diff has worn.
Heres a smart animation showing you the joint in action (its the green bit ;) )
Last edit: 11 Oct 2011 07:29 by adamatdraycott.
  • vitara_mad
11 Oct 2011 07:40 #23470 by vitara_mad
DarrenH 4X4 wrote: ok i have narrowed it doe n to some thing on the right rear side of the car, it sounds like it is coming from the break area, it is not the dif as i have checked it and replaced the oil, so that is all fine. any help would be appricaited, i am a novice at this so ifo & photos will help, thanks.
not alot it can be if its deffo from the rear break area. wheel bearing & break shoes
  • Monkey
11 Oct 2011 07:43 #23471 by Monkey
This!!! I have stuffed break shoes in the rear drums which is making some really bad noises....
Time to create page: 0.160 seconds
