Noice at back diff when excelaration only
  • DarrenH 4X4
04 Oct 2011 08:29 #23011 by DarrenH 4X4
Noice at back diff when excelaration only was created by DarrenH 4X4
I have a 2003 Jimny with the M13A motor in it, when i change gears and excelerate there is a clank type noice at the back of the car, could be rear diff, any ideas greatly appricated, Thanks
  • goatboy
04 Oct 2011 08:45 #23013 by goatboy
Replied by goatboy on topic Re: Noice at back diff when excelaration only
does it clank just once?
Could be a whole host of things that are loose and moving under acceleration...
  • Monkey
04 Oct 2011 08:57 #23015 by Monkey
Check all the radius arms bolts are tight and that all the bushes are ok, that was what was causing the noise from my rear end under power...
04 Oct 2011 09:03 #23016 by mlines
Check for a worn UJ, make sure you do this by undoing the prop shaft completely at the diff end as sometimes the joint can fail in "stiff" mode meaning you cannot feel it just by wobbling the prop shaft.
04 Oct 2011 09:23 #23017 by Johnniehec
As goatboy says it could be a host of things, similar noise on mine was loose lower shock mounting bolt.
John.
  • DarrenH 4X4
06 Oct 2011 23:18 #23183 by DarrenH 4X4
Replied by DarrenH 4X4 on topic Re: Noice at back diff when excelaration only
it only make a clank noise when you change gears and excelerate.
Time to create page: 0.164 seconds
