valve clearances
- small-torque
27 Sep 2011 07:13 #22651
by small-torque
valve clearances was created by small-torque
Hi there. Simple question to ask. I have a 2007 model jimny and wondered if anyone can tell me if the valve clearances are adjustable or hydraulic as my engine is starting to sound a bit tappety on fire up for a couple of minutes. Anyone?:whistle:
27 Sep 2011 14:44 #22678
by facade
Replied by facade on topic Re: valve clearances
Adjustable by flicking out shims and replacing them. Quite a lot of trouble.
If it sounds tappety when cold, it might be piston slap, just at startup check the timing chain tensioner is working.
Actually, a 2007 is a VVT engine: does it have 5/30 oil in it?
How many miles has it done?
- small-torque
28 Sep 2011 05:41 #22706
by small-torque
Replied by small-torque on topic Re: valve clearances
The engine has done 38000 miles and is due its service (actually 2000 miles overdue:blush: ). Not sure about oil. Is 5/30 the correct one to use then?
To check the timing chain tensioner, what do you suggest?
Any advise appreciated, I may just be worrying over nothing:S
28 Sep 2011 17:52 #22736
by facade
Get the oil and filter changed and see if the noise goes.
Suzukis don't like dirty oil, they will seize a cam in no time. :ohmy:
Time to create page: 0.159 seconds
