OBD 2 Scanners - Any recommendations?
31 Oct 2013 20:15 - 31 Oct 2013 20:17 #88809 by Rhinoman
ands wrote: oh. i see. i thought that all Jimnys will have the same standard. anyway, i will just use the Ultra-Gauge in my other car. So I guess even those ELM327 bluetooth scanners wont work right?
No they only work with EOBD/OBD2 although you can use them to determine if it is SDL/KWP if you manually send commands from a terminal emulator such as HyperTerminal. An SDL/KWP ECU will correctly respond with a 'not supported' message when asked for OBD2 data.
Last edit: 31 Oct 2013 20:17 by Rhinoman.
Time to create page: 0.136 seconds
