OBD 2 Scanners - Any recommendations?
24 Oct 2013 03:14 #87691 by kirkynut
I've found most of these devices connect easier if plugged in with the engine already running.
  • ands
24 Oct 2013 03:51 #87700 by ands
Replied by ands on topic OBD 2 Scanners - Any recommendations?
i have also tried to plug the device when the engine is running already. but same thing. seems like the device couldnt communicate with the OBD port. although it can draw power from the port.
24 Oct 2013 12:30 - 24 Oct 2013 12:53 #87730 by Rhinoman
If its a Philippines or Japanese model then it won't be OBD2 it will be a proprietary version of KWP2000 called SDL/KWP. The only tool that will work with that model is the Suzuki factory tool although I am working on an interface that will be compatible. I don't know when that will be ready, its been a long time in development due to other projects.
rhinopower.activeboard.com/t51689605/sdlkwp-protocol/
SDL/KWP is the protocol used worldwide by the dealer tools and gives access to more data and controls, EOBD/OBD2 is an additional interface for 'public' use implemented in markets that mandated OBD2/EOBD. There is more information on the different protocols here:
www.rhinopower.org/diag/diag_main.html
Last edit: 24 Oct 2013 12:53 by Rhinoman.
The following user(s) said Thank You: mlines, ands
  • ands
31 Oct 2013 01:37 #88689 by ands
oh. i see. i thought that all Jimnys will have the same standard. anyway, i will just use the Ultra-Gauge in my other car. So I guess even those ELM327 bluetooth scanners wont work right?
  • vegetablejoe
31 Oct 2013 08:17 #88706 by vegetablejoe
Replied by vegetablejoe on topic OBD 2 Scanners - Any recommendations?
Rhinoman wrote: If its a Philippines or Japanese model then it won't be OBD2 it will be a proprietary version of KWP2000 called SDL/KWP. The only tool that will work with that model is the Suzuki factory tool although I am working on an interface that will be compatible. I don't know when that will be ready, its been a long time in development due to other projects.
Oh boy. Too bad for me. Bought my OBD2 device half a year ago, but couldn't find the OBD2 port under my dashboard. I guess I will never be able to use the gadget then...
31 Oct 2013 20:14 #88808 by Rhinoman
The port will be there irrespective of the protocol, Suzuki used the J1962 connector on all Jimnys.
Time to create page: 0.187 seconds
