Diff/pinion bearing replacement.
- mcjimny
I just MOT'd mine and its got an advisory for it. I knew there was play there and its on the list to look at anyway. Ideally i would like to get it done before winter.
As usual any help is appreciated.
Get another differential and swap it over.
You have to correctly set the pinion bearing preload, adjust the mesh of the crownwheel and preload it.
Most likely if the pinion bearings have gone the crownwheel and pinion will have wierd wear patterns and be as noisy as hell.
Going rate is about £75 for a good diff from a breakers, you won't change the bearings and crush spacer for that.
- vitara_mad
as above getting a replacement diff is the easyest & prob the cheapest option & i know where theres one for sale too
- mcjimny
As i've never touched a diff before is it as simple as pulling the shafts, removing the prop and unbolting the diff?
- vitara_mad
mcjimny wrote: They've marked it as dangerous on the advisory note. Presumably i can keep going until the diff eats itself if i use 4wd? I've not got the money for a few weeks to get a replacement unfortunately.
you also need to undo the brake pipes from the rear wheel cylinders to pull the shafts out
its a easy job to replace a diff
- mcjimny
Its the front - i should have said :blush: It'll be part of other jobs as i'm taking it all apart, i know the discs will need doing next time i do the pads and the kingpins (again :pinch: ) so may as well do it all together.vitara_mad wrote:
