ENGINE OIL LEAK ??
  • myers647
25 Sep 2011 17:24 #22515 by myers647
ENGINE OIL LEAK ?? was created by myers647
Hi Iv got a oil leak coming from the top of my engine its dripping down onto the gearbox. Its right at the back.What ever the part is its attached to the rocker cover its got a couple of wires coming out of it. Its this part that i need to know the name of. I hope this makes some sense. Someone told me its where a distributor would be but its replaced with a blacking plate on this engine but I'm unsure i don':dry: t have a clue really.
thanks:dry:
  • ZookFastback
25 Sep 2011 17:45 #22516 by ZookFastback
Replied by ZookFastback on topic Re: ENGINE OIL LEAK ??
Sounds like the cam angle sensor to me. Is it the G13BB sohc motor? If it is I would be thinking the rocker cover gasket is the culprit. The seal is a round profile silicone gasket and is prone to leaking at the rear (firewall) end. Cheap and easy to replace by any handyman. Just be sure to tighten up equally as you re-fit to stop the silicone bulging or pinching.
  • myers647
25 Sep 2011 17:51 #22517 by myers647
Replied by myers647 on topic Re: ENGINE OIL LEAK ??
thanks for the reply and yes its the G13BB SOHC in a 2000 plate. I think its the sensor to be honest.
thanks
james
Time to create page: 0.144 seconds
