Starting problem
  • Chilgrove
22 Sep 2011 16:21 - 23 Sep 2011 06:37 #22352 by Chilgrove
Starting problem was created by Chilgrove
For the first time my Jimny had trouble starting today. I kind of sensed it was a fuel issue so kept trying and eventually it fired up and worked fine. I have recently fitted a new air filter (not Suzuki part) but surely that would not be the reason? The filter is German, made by Mann.
Should also mention it it not a battery issue as the engine spun over very well, just did not fire.
Last edit: 23 Sep 2011 06:37 by Chilgrove. Reason: More information
23 Sep 2011 15:43 #22402 by facade
Replied by facade on topic Re: Starting problem
You may have dislodged a pipe or the inlet air temperature sensor when you changed the air cleaner, have a good look for loose pipes /wires.
There is a pipe from the manifold to the front wing that provides vacuum. If it is off the car will be hard starting when cold.
  • Chilgrove
23 Sep 2011 20:24 #22418 by Chilgrove
Replied by Chilgrove on topic Re: Starting problem
Thanks facade I will have a look at that.
Time to create page: 0.186 seconds
