Thread sealant
  • Smoggy
11 Sep 2011 17:49 #21669 by Smoggy
Thread sealant was created by Smoggy
Hi everyone, ive just changed all my oils - engine,gearbox,trans and both diffs. Cost me a packet in oil!
In the suzuki manual it recommends applying Suzuki thread sealant to the drain and filler plugs when replacing them. Since I didnt have any and needed to get my car back on the road does anyone know if this will present a problem. Also for next time i need to do my oils is there a generic sealant i could use? Maybe martin has some in the big Jimny shop? Thanks in advance guys.
11 Sep 2011 18:02 #21671 by mlines
Replied by mlines on topic Re: Thread sealant
Yes there is one I can supply, I certainly use one myself.
I will get a price by the end of the week.
The following user(s) said Thank You: Smoggy
  • Smoggy
11 Sep 2011 18:16 #21676 by Smoggy
Replied by Smoggy on topic Re: Thread sealant
Martin, is the sealant to help stop oil leaking through or to make it easier to remove the plugs in future. Excuse my ignorance.
11 Sep 2011 18:35 #21679 by mlines
Its described as sealant/locker, I use it because the plugs are so low in torque that it stops them undoing by themselves. I guess it helps them seal as there is no copper washer on the internal style plugs. Its not a strong locker in fact it doesn't really set.
11 Sep 2011 18:41 #21681 by facade
Replied by facade on topic Re: Thread sealant
It prevents corrosion from outside and stops oil leaks from inside.
I use some loctite thread sealant left over from a job at work years ago. I suppose golden haematite or stag would do the job if you have it.
Put some on next time, it won't explode without it now.
  • Smoggy
11 Sep 2011 18:48 #21684 by Smoggy
Just had a thought and suppose I could smear some on drain plugs by just backing out threads 90%. Fill plugs obviously not a problem :P
