235/75/15
- mostafa
30 Aug 2011 09:57 #21031
by mostafa
235/75/15 was created by mostafa
hi all.....
i have old man emu suspension kit on my 1999 SOHC Jimmy
i wanted to fit 235/75/15...... does anyone have any exp.?
any bad effect or results or tips ?
- Back in Black
02 Sep 2011 05:36 - 02 Sep 2011 05:38 #21165
by Back in Black
Replied by Back in Black on topic Re: 235/75/15
Hi,
Not sure about the emu kit - I have 225/75s fitted to fourtrak wheels with spacers and 2" shock spacers and had to do some cutting to the front arches. Still had rubbing at full lock until I fitted 2" body lift.
I also (still) get the 'wobble' at around/above 60! Next part is a steering damper to try and smooth the ride.
Without the spacers at front the cutting required is less. The offset on the 4trak wheels is bigger than the Jimny wheels, so this might have made a difference too.
Hope this helps?
Hope this helps?
Last edit: 02 Sep 2011 05:38 by Back in Black. Reason: typo
- richardskud
10 Oct 2011 09:06 #23405
by richardskud
Replied by richardskud on topic Re: 235/75/15
hi im currently running on cooper stt 235/75/15 with 3inch lift have steeringdamper reversed sj rims and off road bumpers and have no trouble except occasional rub on drivers side iner body when hitting bumps at speed over 45mph + and have had 30/9.5/15 before. hope this helps
- Dutchjimny
10 Oct 2011 14:18 #23424
by Dutchjimny
Replied by Dutchjimny on topic Re: 235/75/15
I run 235/60/15 Grabber HP's on a stock jimny.. no problem at all
10 Oct 2011 14:42 #23425
by kirkynut
Replied by kirkynut on topic Re: 235/75/15
I know it is daunting enough buying tyres but be aware that different brands come up bigger and smaller than it says on the sidewall.
So it is important to find someone with the same lift, offset of wheels and tyres you plan to get, like you are, so you know what rubbing to expect and what you need to do about it.
Martin has an entry in his blog off the home page about what he did to get this size of BFG MT's to fit and I think Maverick (Brett) is the author of a "How to" article on here covering arch mods.
Hope this helps.
Hope this helps.
Time to create page: 0.148 seconds
