How to remove alternator to replace crank sensor
- Mumbo Jimbo
04 Aug 2011 13:39 #19949
by Mumbo Jimbo
How to remove alternator to replace crank sensor was created by Mumbo Jimbo
Hi, has anyone removed the alternator on their Jimny? I need to remove mine to change my crank sensor, is it just a case of removing the tensioner bar at the top, then removing the bolt it pivots on at the bottom? Can I get away with leaving the bottom bolt and just rotating it out of the way to get at the crank sensor? Any tips would be greatly appreciated, just waiting for a gap in the rain to get on with it.
Cheers
Trevor
Cheers
Trevor
- ooky_123
04 Aug 2011 13:51 #19951
by ooky_123
Replied by ooky_123 on topic Re: How to remove alternator to replace crank sensor
I didnt remove it, I just undid the 2 bolts athat hold it on, slackened the air intake and part of the throttle body off and was able to get in and remove it. Its a fiddly job but easier if you remove the pipework.
- Mumbo Jimbo
04 Aug 2011 13:58 #19952
by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: How to remove alternator to replace crank sensor
Thanks for that, it does look fiddly. Will give it a try in a bit
- Mumbo Jimbo
04 Aug 2011 16:11 #19959
by Mumbo Jimbo
Wasn't as bad as I thought it would be, just got to take it for a run now to see if the engine cutting out when hot problem is gone now.
Cheers for your help ooky_123, I would have wasted time taking the alternator off!
Time to create page: 0.166 seconds
