Jimny Diff ratios
- frede.gv1
10 Mar 2012 18:30 - 10 Mar 2012 19:05 #35252
by frede.gv1
Replied by frede.gv1 on topic Re: Jimny Diff ratios
i am running a 4,16 transfer. but still a bit high if i want a pto with mecannical winch.
sorry for spelling:sick:
Last edit: 10 Mar 2012 19:05 by frede.gv1.
- TomDK
10 Mar 2012 19:09 #35253
by TomDK
So, if having a 2002 non-VVT, I can install VVT ring&pinion gears into my diffs and get a -17% reduction? Or is it the other way around ?
Replied by TomDK on topic Re: Jimny Diff ratios
panosd wrote: If you change the r&p of a non vvt jimny with the r&p of a vvt jimny you will have a -17% low ratio.
You can run tires 235-75-15 with no problem.
It wont be like having a rocklobster but it will seems like a mini rocklobster(410 t-case).
It is tested and works great.
Also you can find from japan spec. jimny with 11/45 diff ratio and do the same.
11 Mar 2012 10:06 #35268
by facade
Replied by facade on topic Re: Jimny Diff ratios
the number is how many times the pinion (ie propshaft) goes round for one turn of the crownwheel (ie wheels) so a bigger number means that the wheels go slower= lower geared.
When we say "lower gear ratio", we actually mean higher to go slower!
- Monkey
11 Mar 2012 12:02 #35272
by Monkey
Replied by Monkey on topic Re: Jimny Diff ratios
'98-'05(change over year) had 4.11 diff's. '05-to current has 4.3 diffs. The difference between the 2 ratio's is about 6% from my research.
- frede.gv1
11 Mar 2012 17:28 #35294
by frede.gv1
mine )2001) is running 3,9-1.
- Monkey
12 Mar 2012 10:31 #35345
by Monkey
3.9.1? :blink: I was not aware that jimny's come out with this ratio!?! :S
