Jimny Diff ratios
- fordy103
06 Jul 2011 17:25 #18655
by fordy103
Jimny Diff ratios was created by fordy103
So, ive been told that apparently the automatic jimny, or a late manual vvt jimny has shorter diff ratios than a none vvt Jimny.
So, anything newer than 2006 has better diffs than the old ones. ( for off roading anyways)
Can anybody confirm this?
James
James
- ooky_123
06 Jul 2011 20:09 #18661
by ooky_123
Replied by ooky_123 on topic Re: Jimny Diff ratios
- dadam
06 Jul 2011 22:47 #18667
by dadam
Replied by dadam on topic Re: Jimny Diff ratios
forgive me if i misunderstood but the topic talks about the DIFF ratios, not the T-Case...
07 Jul 2011 05:05 #18668
Replied by mlines on topic Re: Jimny Diff ratios
So you need to look at the final line in that table that ook123 linked to....
- dadam
07 Jul 2011 08:15 #18678
by dadam
i'm really tired actually, sorry...:blush:mlines wrote: So you need to look at the final line in that table that ook123 linked to....
- panosd
07 Jul 2011 10:02 #18684
by panosd
Replied by panosd on topic Re: Jimny Diff ratios
If you change the r&p of a non vvt jimny with the r&p of a vvt jimny you will have a -17% low ratio.
You can run tires 235-75-15 with no problem.
It wont be like having a rocklobster but it will seems like a mini rocklobster(410 t-case).
It is tested and works great.
Also you can find from japan spec. jimny with 11/45 diff ratio and do the same.
Time to create page: 0.162 seconds
