i need help: what is this noise ( from a pulley )
  • renard38
26 Jun 2011 17:36 #18290 by renard38
hi
i have changed the viscous coupling, but noise again :sick: Have you got ever the same?? Where it's comes from???
A+
26 Jun 2011 19:53 #18300 by facade
Take off the belt for the power steering, by slackening the bolts through the adjuster and see if it is still noisy.
If it is, it may be the alternator bearings, water pump, or even just a worn out fanbelt, or one that needs retensioning.
If it isn't, it may be the tensioner pulley, steering pump or again a worn out drive belt.
  • renard38
27 Jun 2011 09:21 #18311 by renard38
yes, i would do this yesterday in the woods, but i haven't enough tools with me :blush:
this afternoon i go at suzuki dealer in order to see if i can drive with this noise during my holliday ( 2 weeks ) and i'll repair after.
  • panosd
27 Jun 2011 11:21 #18315 by panosd
It's not a big deal. Just go to a suzuki service and ask them to tight up your 2 belts between the fan and the
engine. It takes about 5 minutes to do both.
Its easy for them to do that because of a special tool that they have for this job.
  • renard38
27 Jun 2011 16:07 #18322 by renard38
the belts don't slide on the pulley.
I have see suzuki dealer and they told me the only methode is to put a belt after another. That of the alternator and then the power steering .
  • panosd
27 Jun 2011 16:48 #18323 by panosd
I had the same problem in the past and that was the solution. I ask me friend at local suzuki and he told me
the same for what i asked him and explained him.
Do you have install the proper belt? The width is ok?
If you have done this , then the only thing left is to make it tight.
