i need help: what is this noise ( from a pulley )
- renard38
27 Jun 2011 16:57 #18325
by renard38
Replied by renard38 on topic Re: i need help: what is this noise ( from a pulley )
yes, i have installed the good proper belt; and The width is ok.
28 Jun 2011 08:04 #18351
by Obarno
Replied by Obarno on topic Re: i need help: what is this noise ( from a pulley )
It sounds like a belt - try putting a little chalk dust onto the belt and if it stops the squeaking you have found the problem.
To make sure its not the alternator, water pump, power steering pump, idler pulley etc take a long handled screwdriver and place it (carefully) on each item and listen to the noise - like a stethoscope. You will quickly hear if a bearing is going on something.
- renard38
28 Jun 2011 18:36 #18369
by renard38
i have ever taked a long handled screwdriver and place it (carefully) on each item and listen to the noise: all is ok, no strange noise
- panosd
29 Jun 2011 08:29 #18381
by panosd
Replied by panosd on topic Re: i need help: what is this noise ( from a pulley )
Take off the 2 belts and apply on them a small amount of vaselini in order to make them soft.
The squising noise will stop.
29 Jun 2011 10:43 #18384
by Obarno
It definitely sounds like the belt then. An easy way is to spray a little WD40 onto the belt whilst the engine is running - one at a time if you can. The noise will disappear if its the belt.
- renard38
29 Jun 2011 16:58 #18408
by renard38
no, no it's not the belts; There is a big difference when a belt slide.
on this vidéo, you can hear the belts (belt not slip but is too dry; changed now ):
This afternoon, i controlled the pulley dumper: OK
I then put a single belt (that of the alternator and water pump), there was a very slight noise which increased when I turn the headlights, so maybe the alternator ...
