Suspension question
- darthloachie
22 Jun 2011 08:22 #18123
by darthloachie
Replied by darthloachie on topic Re: Suspension question
If you are fitting the ora bumpers you won't need to trim the bumper as they are designed to work with larger tyres
22 Jun 2011 09:37 #18126
Replied by mlines on topic Re: Suspension question
If you want to add more lift to a Trailmaster 2" lift without going down the Castor Correction/Trailing Arms route then take a look at a Body Lift. As these move the chassis as a whole unit they don't affect the castor etc.
The following user(s) said Thank You: Seawolfvarna
- Seawolfvarna
23 Jun 2011 02:55 #18149
by Seawolfvarna
Replied by Seawolfvarna on topic Re: Suspension question
Hi, Martin
Thank you for your reply!
I am planning to fix body lift as well - 2" or may be even 3".
I am doing all this in order to fix some bigger tyres - as 30" for example.
Only with 3"lift with out body lift, I believe that will be no possible.
Now I understood, that if I upgrade this lift to 3", then will be necessary to fix some flanges on both propeller shafts. It will be nice if some can share experience with size, material and way of fixing of this flanges. Is it necessary to fix for both propeller shaft or only on rear one?
Yours:
Nikolay
Yours:
Nikolay
23 Jun 2011 05:48 #18152
by MigCooper
Snorkel and plenty of rust to be treated
Replied by MigCooper on topic Re: Suspension question
I am fitting 30" tires today or tomorrow.
Jimny has 3" lift plus 1" spacers, will let you know how it worked latter
- supergaz
23 Jun 2011 06:06 #18153
by supergaz
Replied by supergaz on topic Re: Suspension question
Prop spacers are only needed if caster correction for 3'' or above is used. I have a 4.5'' lift with castor correction for 4.5'' lift and use a 1'' prop spacer only on the transfer box end of the front prop.
I have also just fitted a 2'' body lift from jimnybits as he can also supply steering shaft spacers, these are highly recommended on a 2'' body lift and above.
- Seawolfvarna
23 Jun 2011 08:31 #18155
by Seawolfvarna
Hi MigCooper
That will be very nice to share your experience.
Do you have any modifications on your T-case , or diff perhaps - new pinion shaft and crown shaft?
Yours
Nikolay
MigCooper wrote: I am fitting 30" tires today or tomorrow.
Hi MigCooper
Yours
Nikolay
Time to create page: 0.162 seconds
