Suspension question
  • Seawolfvarna
24 Jun 2011 18:24 #18235 by Seawolfvarna
Replied by Seawolfvarna on topic Re: Suspension question
MigCooper wrote: I have the standard rims with no offset, but I fitted 32mm spacers ;)
Hi MigCooper
I ordered already steel wheels with -30 offset. In that case I believe, that if you fit your 30" with 32mm spacers on original wheels, than may be I will be able to fix 235/75/R15.
Did you try already your monster.
How is power performance? Do you will some lack of power?
Cheers
  • Monkey
24 Jun 2011 21:35 #18238 by Monkey
Replied by Monkey on topic Re: Suspension question
Hi MigCooper
Cheers
You are going to have BIG scrubbing issues with ANY size tyre that you choose cus of the huge off set.
Migcooper: I think you should consider buying some new wider rims for those 30"sx9.5 here in AUS it it illegal to run anything bigger than a 215's on a 5.5" wide rim. You will also get more life out of your tyres, say with a 15x7" rim.
  • Seawolfvarna
25 Jun 2011 05:25 #18240 by Seawolfvarna
Monkey wrote:
Hi MigCooper
Cheers
The rims are with following specifications:
7" x 15" 5x139.7x 110 ET -30
So in that case is it possible to avoid wheel spacers?
Yours
Nick
  • Monkey
25 Jun 2011 05:29 #18241 by Monkey
Seawolfvarna wrote:
Monkey wrote:
Hi MigCooper
Cheers
Yours
Nick
Yes i run 15x7's -13 and even that feels very stable, but you are going to need to trim your guards due to the size of your off set...
  • Seawolfvarna
25 Jun 2011 06:44 #18244 by Seawolfvarna
Certainly, I already red the article in "How to" section.
I will do it!
Cheers
  • Seawolfvarna
26 Jun 2011 16:33 #18284 by Seawolfvarna
Did somebody know, what is the max size of tyres which you can fit on 7"x15" rims?
31"can be fitted there or not?
Thank you
Time to create page: 0.761 seconds
