my diff
  • Monkey
27 Jun 2011 07:02 #18307 by Monkey
Replied by Monkey on topic Re: my diff
jason92 wrote: also slow movment on flat ground on full lock rear diff seames to be draging if going very slow and let off the car stops like it had a binding handbreak but checked out the breaks and there all gd no binding i think its just the diff draging?? i checked the oil in the diff and its a gd level but the front diff oil is ordinery diff oil colour but the rear diff the one i think i got problems with has red oil in ?? any idears?? thanks jason
I have the same problem word for word my is doing the same thing :angry:
  • panosd
27 Jun 2011 09:48 #18312 by panosd
Replied by panosd on topic Re: my diff
90% is the rear cross of the axle from the t-case to the rear diff. You need to change it.
To find out that try to turn the central axle from t-case to r. diff with your hand and see if it is loose.
Or the other 10% is the rear flange from the rear diff where fits the axle from t-case to the rear diff.
To find out that you can look for oils at this point of your rear diff.
According the noises and the time that the noises appeared one of the abbove is your problem.
Hope help you that.
  • Monkey
27 Jun 2011 09:53 #18313 by Monkey
panosd wrote: 90% is the rear cross of the axle from the t-case to the rear diff. You need to change it.
Hope help you that.
I think that;s wear my problem is :(
  • panosd
27 Jun 2011 11:24 #18316 by panosd
If this is its ok. Is cheap to fix it. A ''cross'' is about 15euros or 42euros for a racing and more durable one.
It takes no more than 25min to change it. You can find on the net a how to guide.
  • ianR
22 Apr 2012 23:01 #38379 by ianR
Replied by ianR on topic Re: my diff
I have this problem aswell, what is meant by rear cross, sorry in advance if it a dumb question !!
23 Apr 2012 06:01 #38383 by facade
Replied by facade on topic Re: my diff
Rear cross = universal joint "spider" or hooke joint.
Grab the axle flange and the propshaft tube and try twisting by hand, you will feel any play.
15 euros is an absolute steal. The only one I could find in the UK apart from suzuki is a blueprint part, and they retail at over £40 :ohmy:
size 25 x 63.8 mm
Quinton Hazel QL219 or ql529 (with grease nipple) good luck getting one.
Blueprint ADK83901
