my diff
  • adamatdraycott
23 Apr 2012 07:27 #38385 by adamatdraycott
Replied by adamatdraycott on topic Re: my diff
Tip on fitting a UJ
Use a vice and a socket to press the cups out. You won’t do it with a hammer like on the YouTube Videos.
It’s a job that should take no more than a couple of hours, including removing and refitting the shaft. Mark the shaft to make sure you drop it back in the same orientation
  • ianR
23 Apr 2012 20:26 #38428 by ianR
Replied by ianR on topic Re: my diff
facade wrote: Rear cross = universal joint "spider" or hooke joint.
Grab the axle flange and the propshaft tube and try twisting by hand, you will feel any play.
15 euros is an absolute steal. The only one I could find in the UK apart from suzuki is a blueprint part, and they retail at over £40 :ohmy:
size 25 x 63.8 mm
Quinton Hazel QL219 or ql529 (with grease nipple) good luck getting one.
Blueprint ADK83901
I have a rocklobster box and use the SJ front prop on the rear will the UJ be the same size and part number ?
  • adamjimny
23 Apr 2012 21:35 #38446 by adamjimny
Replied by adamjimny on topic Re: my diff
It was for me because i put jimny end bit on sj prop so it bolted on dead easy
sent from my Samsung Galaxy S2 using Tapatalk
23 Apr 2012 23:16 #38459 by facade
Replied by facade on topic Re: my diff
The SJ413 is the same part.
Measure it: the hole in the yoke is 25mm, the 63.8 is the measurement across one arm of the spider.
The SJ410 uses one that is only 40mm across.
Alternate widths on a 25mm joint are: 56.9 and 76.8, you should be able to tell with a ruler if yours is going to be 63.8mm across. (The yoke has to be about 6mm wider than the joint.
  • ianR
25 Apr 2012 11:07 #38556 by ianR
On inspection last night the uj's are all fine.
What else could the problem be ?
The only thIng I have changed is fitting a rocklobster box.
Could it be that the lower ratio is causing my diff locker to pull in as I pull away and the side with the shorter shaft is the one that pulls down ??
  • darthloachie
25 Apr 2012 12:31 #38566 by darthloachie
Replied by darthloachie on topic Re: my diff
check your transfer box is not moving under torque - also check there is no wear in the splines on the prop - both are easy to check by giving the prop a shake and look for any movement
if you've got a lift you're putting more stress on both items due to the increased angles they're working at
