Rocklobster Question
  • ooky_123
15 years 5 months ago #17881 by ooky_123
Rocklobster Question was created by ooky_123
Well after spending most of the afternoon under the car, attempting to fit the Rocklobster, I managed to get the car running in front wheel drive, and took it to my local garage to help me drill the rear diff flange.
Here is a photo of the finished article
I do have one problem though, I havnt bent the gear stick yet, so the transfer box is currently stuck in 4 Hi. I assume I need to get it bent back to allow me to select 2Hi.
Also, can someone give me a photo of the gear pattern .. Is it the same as the Jimny ?
2Hi --- 4Hi (push down) -- 4Lo ??
15 years 5 months ago - 15 years 5 months ago #17887 by MigCooper
Replied by MigCooper on topic Re: Rocklobster Question
Hi
On the lobster the patter is as follows:
.............4L
2H....... N
4H
Dont mind the dots, forum removes the spaces so had to redo this ..... :ohmy:
Snorkel and plenty of rust to be treated :)
Last edit: 15 years 5 months ago by MigCooper.
  • ooky_123
15 years 5 months ago #17889 by ooky_123
Replied by ooky_123 on topic Re: Rocklobster Question
Also just noticed after a quick test drive that the gear stick seems to be touching either a UJ or a balance weight if you push down on it when changing gear ... a common problem #?? maybe need to go slightly higher on the lift ... ?
15 years 5 months ago #17891 by mlines
Replied by mlines on topic Re: Rocklobster Question
The change pattern on a Rock Lobster is in the shape of a backwards J
2H at the top
4H at the bottom
4L at the tip of the "hook"
  • ooky_123
15 years 5 months ago #17892 by ooky_123
Ahh that explains it then ... even with a 1" cut in the floot, i cannot select the 2Hi (Neutral) position ... ok, so bending is essential ...
MigCooper wrote: Hi
4L
2H N
4H
15 years 5 months ago #17893 by MigCooper
.............4L
2H....... N
4H
Time to create page: 0.096 seconds
