Rocklobster Question
16 Jun 2011 16:11 #17894 by mlines
Replied by mlines on topic Re: Rocklobster Question
ooky_123 wrote: Also just noticed after a quick test drive that the gear stick seems to be touching either a UJ or a balance weight if you push down on it when changing gear ... a common problem #?? maybe need to go slightly higher on the lift ... ?
You get a "ting", "ting", "ting" noise. I had this, its the bolts are too long on one of the flanges if I remember correctly, they foul something.
It gets worse when you "load" the transmission (i.e. steep hill start)
16 Jun 2011 16:21 #17896 by MigCooper
Replied by MigCooper on topic Re: Rocklobster Question
I got the same cutting the bolts solved it as well
Snorkel and plenty of rust to be treated :)
  • andyw
16 Jun 2011 16:35 #17897 by andyw
Replied by andyw on topic Re: Rocklobster Question
I'm sure It's
....................4 L
....................l
...................__ N
2H...............l
l...................l
l_________l 4H
you get the idea lol..................................get the oxy on it to get a good kink in the stick, really red and it will bend where you want it and not like a bananaB) .......or some people grind it nearly through and then weld it.
Andy
16 Jun 2011 16:57 #17900 by mlines
Ok - I had it the wrong way around.
Attachment sized_IMGP7523.JPG not found
  • ooky_123
16 Jun 2011 18:27 #17906 by ooky_123
Replied by ooky_123 on topic Re: Rocklobster Question
Thankyou Martin / everyone. I think a visit to my local garage to get the gear stick bent and I guess im off to look for a genuine gear knob
  • ooky_123
23 Jun 2011 21:55 - 23 Jun 2011 21:56 #18197 by ooky_123
Sorry .. Both wrong !!! .. I was looking at the problem today, and it appears to be speed specific .. so, with the lobster box in neutral, and the jimny in Gear, i started to investigate.. The problem appears to be a balancing weight on the mini prop is fouling the bottom of the gearstick assembly. It is more prominent when the gear selector is in the rear position (2nd, 4th, Reverse).
Closer inspection, the underside of the gearstick is on rubber bushes, and these have quite a lot of play. Now .. ignore or try and fix the problem ???...
Last edit: 23 Jun 2011 21:56 by ooky_123.
Time to create page: 0.216 seconds
