Props
  • ooky_123
13 Jun 2011 16:48 #17726 by ooky_123
Props was created by ooky_123
Well, started with good intentions of fitting the RockLobster that has been sat in the shed for almost 2 months and have hit a bit fo a snag ...
Below is a picture of the 2 props I have to use
Now unless im being megga thick (which is a possibility! ) ... the mini prop I have on teh Jimny has a pair of flanged ends where as the one in the above picture has a splined end ...
I just wanted to check with the masses if I should split the UJ and just use the standard Jimny flange that is on the gearbox.....
13 Jun 2011 17:22 #17731 by kirkynut
Replied by kirkynut on topic Re: Props
The Jimny mini prop has a splined end too. Just ran out and took a quick piccie of my old one for you:
Attachment IMGP0050.jpg not found
How does this compare to your Jimny one???
  • ooky_123
13 Jun 2011 17:42 #17737 by ooky_123
Replied by ooky_123 on topic Re: Props
That's a relief ... I havnt taken the mini prop off. I was checking andng all the bolts.
I looked up at the prop and panicked ... Cheers for that. I'll crack on !!
Time to create page: 0.166 seconds
