4WD Problem
- Thank you received: 13
09 Jun 2011 11:03 #17563
by MigCooper
Snorkel and plenty of rust to be treated
4WD Problem was created by MigCooper
Ok so here we are again
since a few weeks ago I cant change the T-Case from 2WD HI to 4WD HI wile moving but it works fine wile stationary ...
Any ideas why that's it?
I have a lobster installed and it was working when I got it .. but stopped doing it at some stage.
I was trying it in low speeds and it goes like if you try to change gear without clutch ...
Thanks for the help coming
09 Jun 2011 11:21 #17564
by MigCooper
Replied by MigCooper on topic Re: 4WD Problem
Just a add on
If I conect the hubs before hand then the change will work fine ....
- Keefe
09 Jun 2011 12:37 #17567
by Keefe
Replied by Keefe on topic Re: 4WD Problem
If the hubs are connected does that mean that the front prop is turning?
If so, then it must make it easier for the gears to mesh rather than if they are stationary and so not able to mesh easily or at all.
Does that make sense?
Have the problem of knowing what I want to say but can't type it!
K
K
- Keefe
09 Jun 2011 12:38 #17568
by Keefe
Forget that dribble above.
You do say that it used to do it ok before.
I'll go and stand back in the corner again.
09 Jun 2011 12:48 #17569
by MigCooper
Hi Keefe
yes it used to do it.
How come they do it the the prop going to the front is stopped anyway ??? (if hubs are disconected)
Thanks for the help anyway
- Thank you received: 115
09 Jun 2011 13:12 #17570
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: 4WD Problem
When you say 'moving' ... i really hope you mean under 5mph!!
I wouldnt even think about moving anything in my T-Case at any speeds higher than 5mph...
Jalapeño, IISY?
Time to create page: 0.164 seconds
