4WD Problem
  • ShuDuck
09 Jun 2011 13:14 #17571 by ShuDuck
Replied by ShuDuck on topic Re: 4WD Problem
so I take it you have a sj t-case? Have your hubs becomed unlocked? because if the front prop is not moving the same speed at the rear, there is no way you will be able to engage 4H. A broken birfield could cause the prop not to spin as well. The jimny uses a syncronizer to speed up the front prop before engaging 4h
09 Jun 2011 13:36 #17572 by MigCooper
Replied by MigCooper on topic Re: 4WD Problem
Thanks ShuDuck
Birfield ?? is that the CV joint? if so is there any simple way of checking if they are ok ???
Snorkel and plenty of rust to be treated :)
09 Jun 2011 13:40 - 09 Jun 2011 13:40 #17573 by MigCooper
maverick wrote: When you say 'moving' ... i really hope you mean under 5mph!!
I wouldnt even think about moving anything in my T-Case at any speeds higher than 5mph...
Maverick
You can change between 2H and 4H up to 80 kph acording to the manual as long as you are driving strait ;) and it used to work like that just fine :angry:
Last edit: 09 Jun 2011 13:40 by MigCooper.
09 Jun 2011 13:47 #17574 by maverick
Replied by maverick on topic Re: 4WD Problem
and you have a SJ T-Case now ... ???
If you do, i (repeat) wouldnt chance any changing of anything in my SJ T-Case over 5mph.
Jalapeño, IISY?
09 Jun 2011 14:07 #17576 by MigCooper
yes I do. are they different in that way ?? if so ok it is not a problem then
09 Jun 2011 14:56 #17578 by facade
Replied by facade on topic Re: 4WD Problem
A jimny can engage 4wd at speed, because the transfer box was redesigned to cope with it. (It was a selling point in 1999; had a spiffy name like "Power command all wheel drive system with knobs on")
As far as I know an SJ, same as a Jeep or a Landrover will go into 4wd at reasonable speeds provided the front hubs are locked (=driving) as both props are rotating at the same speed. (actually, there has to be a tiny speed difference, or the teeth could be permanently out of line so it won't go in)
If the front hubs are freewheeling it will not go in as the speed difference between the front and back shafts is too great (the front shaft is stationary), but there is no point putting it in 4wd if the hubs are free as there would be no drive at the wheels..............
Time to create page: 0.575 seconds
