sj transfer box
  • Cider
28 May 2011 20:35 #17042 by Cider
sj transfer box was created by Cider
Hi
What model sj transfer box do I need if I what to run larger tyre size
Thanks
Pete
28 May 2011 21:07 #17043 by MigCooper
Replied by MigCooper on topic Re: sj transfer box
Cider
You can have a look around and will find loads on this subject, but for starters you need a SJ413 transfer case and 2 SJ axles the mini one and the front one to fit the Jimny rear .... More to that you also need a mounting kit to fit the case in the Jimny, you can get one in ORA ( www.offroad-armory.com )
Have a look at the manuals section ( here
the manual you need is ( How to fit an SJ Transfer Case ) number 11
B) do some introduction and get some pics of your jimny for us ;)
Snorkel and plenty of rust to be treated :)
29 May 2011 05:55 #17048 by maverick
Replied by maverick on topic Re: sj transfer box
I have an 6:1 SJ 413 box and kit, made and supplied by Rob Storr. It came with all the altered props. Rockwatt (Richard) is the new T-case king.
I didnt change any axles or differentials - there's no need to as they are they same.
Hope this helps?
Jalapeño, IISY?
  • Keefe
29 May 2011 09:50 - 31 May 2011 08:58 #17052 by Keefe
Replied by Keefe on topic Re: sj transfer box
I think you'll find MigCooper meant prop shafts not axles. ;)
Last edit: 31 May 2011 08:58 by Keefe. Reason: spelling
31 May 2011 05:49 #17129 by MigCooper
Keefe wrote: I think you'll find MigCooper meant prop shafts not axels. ;)
Yes yes .... prop shafts :laugh: thanks Keefe B)
Time to create page: 0.144 seconds
