Vibration HELP!!!
23 May 2011 10:06 - 23 May 2011 10:07 #16823 by MigCooper
Replied by MigCooper on topic Re: Vibration HELP!!!
Will try that when I get a chance and see what happens ....
Need to sort out vacuum system as last time out the vacuum pipes got damaged after a tree branch pull then ....
Snorkel and plenty of rust to be treated :)
Last edit: 23 May 2011 10:07 by MigCooper.
23 May 2011 10:16 #16825 by MigCooper
goatboy wrote: May sound like a daft question but is the lever physically vibrating or is it just making a vibrating noise from that general area?
(not that I have any idea what it is but just thinking aloud really...)
It is a physical vibration. you can see the lever moving all over the place :unsure:
  • goatboy
23 May 2011 12:51 - 23 May 2011 12:55 #16843 by goatboy
Replied by goatboy on topic Re: Vibration HELP!!!
sounds like a process of elimination is needed like Martin says (and you are already doing).
If its a new box with new mounts and it still does it without the front prop then that must only leave the rear prop/diff/axle.
Edit: Just a random thought did it do it before you put your transfer box guards and everything on? Don't see how it would effect it but you never know...
Last edit: 23 May 2011 12:55 by goatboy.
23 May 2011 13:29 #16847 by MigCooper
Thanks goatboy
Yes it use to do it, but since I was going to change the t-box and believed that was the problem never looked at it .....
will see after fitting the new t-box mounts from ORA
23 May 2011 17:00 #16863 by facade
Replied by facade on topic Re: Vibration HELP!!!
Sounds to me like a buckled wheel or a bent propshaft, but you say you changed the propshafts with the transfer box.
23 May 2011 18:41 #16867 by MigCooper
facade wrote: Sounds to me like a buckled wheel or a bent propshaft, but you say you changed the propshafts with the transfer box.
Yes I did .... unless by a big coincidence both rear props where bent :blink:
Time to create page: 0.169 seconds
