Vibration HELP!!!
22 May 2011 12:59 #16724 by MigCooper
Vibration HELP!!! was created by MigCooper
I am at a dead end with my Jimny.
Almost since I bought my Jimny I noticed a vibration in the Transfer case leaver. Tried to find the source of the problem for a wile but got no where .... in the meantime I decided to buy a rocklobster and waited until then thinking the problem could be the transfer case .... changed the transfer case last week and found the rear gearbox mount was broken, so changed that as well and "yes" it is still the same actually got much worst until I took it off-roading yesterday and got back to what it used to be.. the vibration is quite strong specially up hill and it disappears completely at around 25mph regardless of the gear selected .... since 2 drive shafts and the transfer case were changed I don't know what more to try except I ordered new transfer case mounts for the sake of it .....
Anyone ideas would be great ... Thanks :(
Snorkel and plenty of rust to be treated :)
23 May 2011 06:10 #16806 by MigCooper
Replied by MigCooper on topic Re: Vibration HELP!!!
No one with ideas? :(
  • Keefe
23 May 2011 07:36 #16812 by Keefe
Replied by Keefe on topic Re: Vibration HELP!!!
Prop shafts out of balance. Lost the balance weights from the shaft?
Happened to me in an Escort van.
Vibration got that bad that at 60 mph, the gear lever would come out of the box!
23 May 2011 07:50 #16813 by MigCooper
Thanks keefe
I though about that as well but since I installed the new t-case 2 shafts where changed (mini prop and rear prop) and I drove the car without the front one for a test. I was looking at the ones installed now and they seem to have all the original weights.
thanks for the idea anyway ... I am really at a dead end with this :(
  • goatboy
23 May 2011 09:48 #16819 by goatboy
Replied by goatboy on topic Re: Vibration HELP!!!
May sound like a daft question but is the lever physically vibrating or is it just making a vibrating noise from that general area?
(not that I have any idea what it is but just thinking aloud really...)
23 May 2011 09:52 #16820 by mlines
Replied by mlines on topic Re: Vibration HELP!!!
As well as driving without the front one I would also try driving without the rear one.
Remove the rear propshaft and put it in 4wd. You will then have a front wheel drive vehicle, see what happens then.
Time to create page: 0.170 seconds
