Fitting single electrics to a towball.
- Municipal Waste
22 May 2011 12:07 #16722
by Municipal Waste
Replied by Municipal Waste on topic Re: Fitting single electrics to a towball.
Hmm, I quite like the location you put yours in SRCARS, I think it might be a good idea especially if I've got to have the bumper off to do the job anyway!
I think next time I've got a chance I'll pop into The Range and see what theirs is like and then try fitting that first before I even get the towbar TBH.
Just going to have a go at changing my bulbs for some brighter ones. I'm quite the novice at working on cars... Show me a push bike and I can fix anything but this is scarey and new
- Municipal Waste
30 May 2011 18:17 #17114
by Municipal Waste
Joints like this yes?
- srcars
30 May 2011 18:48 #17117
by srcars
Replied by srcars on topic Re: Fitting single electrics to a towball.
Although I have and still do like to use solder and heatshrink on some joints as they are much neater especially when tapping into a wire I have read somewhere it is not ideal. Automotive wire is nearly always multistrand wire as it is very flexible, when you solder it you create a rigid point in the wire which with the constant vibration of a car can over a period of time become brittle and snap.
I have only ever seen this in classic cars I have messed with in the past so your talking about 20 odd years down the line and I doubt my Jimny will still be about then
- ooky_123
31 May 2011 08:46 #17134
by ooky_123
Replied by ooky_123 on topic Re: Fitting single electrics to a towball.
I mounted my Tow Electrius to the rear door near the hinges.
The wiring goed though the rubber duct into the body and then is routed out of sight.
I use a 1 Meter coiled extension to attatch to a trailer.
This keeps the electrics clear of 90% of the water we go wading though
- Johnniehec
- Thank you received: 56
31 May 2011 15:30 #17146
by Johnniehec
Replied by Johnniehec on topic Re: Fitting single electrics to a towball.
I fitted mine same as srcars but at the other side. It's a pig of a job, instructions/guide and wiring diagram here,
www.bigjimny.com/images/documents/jimny_towbar_install.pdf
Scratched knuckles,rusty bolts, broken trim clips are inevitable, wonder why no one has invented a wireless version??
John.
John.
- srcars
01 Jun 2011 04:28 #17160
by srcars
:whistle: Yes I fitted mine on the wrong side really, I read the article on fitting a towbar months before I fitted the socket and for some reason thought the electrics were on the offside. I ended up removing the whole of the rear interior instead of half of it
Fitting socket 10-15 mins, removing and reinstalling interior seemed like an hour :laugh:
Johnniehec wrote: I fitted mine same as srcars but at the other side. It's a pig of a job, instructions/guide and wiring diagram here,
John.
Time to create page: 0.527 seconds
