Fitting single electrics to a towball.
  • Municipal Waste
21 May 2011 08:07 #16639 by Municipal Waste
Fitting single electrics to a towball. was created by Municipal Waste
So I've found somewhere that looks like they're making a half decent fixed tow ball for the Jimny that will be easy to install and can have the type of ball with a closed recovery point built in.
This is their wiring kit:
www.towbars-uk.co.uk/product/26/standard-single-electric-kit
Will this be an easy enough thing to fit and is there a better one I should consider?
While I'm at it this is the tow bar and ball, what do you think?
www.towbars-uk.co.uk/product/7055/suzuki-jimny-
www.towbars-uk.co.uk/product/46/3.5-tonne-ball-and-pin-
:ohmy:
  • dirtydogz
21 May 2011 09:50 - 21 May 2011 09:51 #16647 by dirtydogz
Replied by dirtydogz on topic Re: Fitting single electrics to a towball.
The towbar and the wiring kit are ok but save your money and buy the 50mm tow ball for about £7.
Attachment DSCF1395_2011-05-21.JPG not found
www.bigjimny.com/images/documents/jimny_towbar_install.pdf
Hope this helps.
DIRTYDOGZ.
Last edit: 21 May 2011 09:51 by dirtydogz.
  • srcars
21 May 2011 17:35 #16666 by srcars
Replied by srcars on topic Re: Fitting single electrics to a towball.
I havent fitted a tow bar but I fitted electrics for my bike rack. Fitted the socket right up out of the way to prevent damage offroad. Just an idea if you dont mind drilling into your bumper.
21 May 2011 18:09 #16669 by facade
I have a combi hitch type, it wasn't anywhere near £40 though.
I leave the ball&pin inside the car, with just the jaws on the towbar, and it saves obstructing the number plate.
I certainly wouldn't pay £40 for one.
The electric kit is a good buy, I paid more than that for the cable and a mounting plate for the spare socket I had in the garage.
  • srcars
22 May 2011 05:11 #16694 by srcars
If you have a 'The Range' store near you have a look in there for the electric kit. They dont list it on the website for some reason but they had them when I did mine and it was really cheap ;)
  • mcjimny
22 May 2011 11:07 #16720 by mcjimny
Replied by mcjimny on topic Re: Fitting single electrics to a towball.
That socket in the bumper is a very tidy job, thats on my list to do to mine. I nailed the bracket on mine on its first outing after fitting, id just have to extend the trailer plug but it will make for a tidier and more reliable install as it is quite vulnerable in its current position.
Time to create page: 0.239 seconds
