Slipping out of low range...
- andyw
20 May 2011 13:55 #16607
by andyw
Sort the stick out, you'll be lucky to get it water tight any other way mate,:whistle: then the carpet starts to hum:pinch:
Andy
Replied by andyw on topic Re: Slipping out of low range...
Andy
- noggin
20 May 2011 19:02 #16619
by noggin
Replied by noggin on topic Re: Slipping out of low range...
Ah, fair point... lack of carpets may help with the smell but not really the point. A bit of heat from my blow lamp and bend it?
Craig G(Noggin)
Craig G(Noggin)
- andyw
20 May 2011 20:27 #16624
by andyw
If you can get to oxy heat the better and quicker it will be for you, I did'nt need to bend my jimny lever as I cut the tunnel for speed :blush: ..........but when fitting the rocklobster I needed the heat to bend the lever, you need It red hot or hotter to get a bend.
Safer to do it in a vice;) also a blow lamp might warm the hole lever up before it's hot enough to bend where needed.
Andy
Andy
- doncarlyon
21 May 2011 08:17 #16641
by doncarlyon
Replied by doncarlyon on topic Re: Slipping out of low range...
My mate cut a small wedge out of mine, then bent the lever forward, welded it up and its spot on!
Time to create page: 2.921 seconds
