Slipping out of low range...
- noggin
18 May 2011 19:59 #16530
by noggin
Slipping out of low range... was created by noggin
Hi,
took my Jimny laning today on the way home to test it and found the low range sometimes disengages (as the previous owner advised me) whilst you're going along... are there any common issues with this or am I looking at a new transfer box?
If so... where would I look for a rocklobster?
Thanks
Craig G(Noggin)
Thanks
Craig G(Noggin)
19 May 2011 05:03 #16537
Replied by mlines on topic Re: Slipping out of low range...
I have not heard of this being common.
However, looking at the specification of yours shows its got a 1.6 Vitara Engine in it. There are a number of ways to fit these engines varying from using an engineered adaptor plate and replacement engine mounts through to the "big hammer and electric drill" method. The latter method is quite common as its cheap, but it can result in the engine and drivechain not being properly aligned. I would remove the rubber boot from around the transfer box lever inside the car and watch what happens as you drive along. Look for the box moving and hitting the transmission tunnel, knocking it out of gear. This can also happen if a mount is broken. Also check underneath that the propshafts have some movement left on the splines. If its all be jammed in there then the shafts may be completely compressed to the end of the splines not allowing any natural give in the system.
- goatboy
19 May 2011 05:37 #16539
by goatboy
Replied by goatboy on topic Re: Slipping out of low range...
has it had a body lift?
www.bigjimny.com/index.php?option=com_ku...4385&Itemid=75#14437
- andyw
19 May 2011 07:25 #16544
by andyw
Replied by andyw on topic Re: Slipping out of low range...
It can happen if you've got a bodylift and not bothered to re-shape the t-case shift, from memory it catches the rear right hand side of the hole in the tunnel, I cut a U shape because I did'nt have heat..........GO and find someone who has lol.
It pops out when flexing or just when you dont need it to do,:evil:
Hope you sort it
Andy
Hope you sort it
Andy
- Johnniehec
- Thank you received: 56
20 May 2011 08:12 #16590
by Johnniehec
Replied by Johnniehec on topic Re: Slipping out of low range...
Here's another solution to the problem caused by a 30mm body lift!:laugh:
Attachment IMG_05441.JPG not found
- noggin
20 May 2011 13:35 #16606
by noggin
Replied by noggin on topic Re: Slipping out of low range...
Hmmm.... I'm not sure that's the answer I'm after Johnnie! Today however I have removed the gaiter and found the shell has been cut away to facilitate the lever already but I think it was the gaiter itself causing the problem!
So some modifications to the boot gaiter may be a cheap way out of this problem methinks!
Craig G(Noggin)
Craig G(Noggin)
Time to create page: 0.344 seconds
