Lift topic for techies
- little monster
23 Apr 2011 06:52 #15365
by little monster
Lift topic for techies was created by little monster
Hi Guys
Done my 2" lift & have now decided i need castor correction bushes, so my big question is can i fit the bushes without taking the springs back off, all input will be greatfully recieved as usual
23 Apr 2011 07:08 #15367
by MigCooper
Snorkel and plenty of rust to be treated
Replied by MigCooper on topic Re: Lift topic for techies
yes you can ... remove the radios arms just by removing the 3 crews holding them 2 in the front and 1 in the chassis and of you go .... just a warning, you will need a proper press to remove the old one. my ones took 5 tone to get out ... :ohmy:
23 Apr 2011 07:59 #15369
by Obarno
Replied by Obarno on topic Re: Lift topic for techies
One other thing too is to do one side at a time, otherwise the axle will move and make it difficult to put back together.
- srcars
23 Apr 2011 08:10 - 23 Apr 2011 08:10 #15370
by srcars
Replied by srcars on topic Re: Lift topic for techies
As above best to remove one radius arm at a time, I did mine togeather and thought the axle would be fine on axle stands
Took some major welly to get it back on single handed. I ended up removing the bushes the manual way because I was impatient and it not to bad a job. Guide here
www.bigjimny.com/images/documents/fittin...orrection_bushes.pdf
Last edit: 23 Apr 2011 08:10 by srcars.
- little monster
23 Apr 2011 10:11 #15375
by little monster
Replied by little monster on topic Re: Lift topic for techies
Cheers guys helpfull as ever
- myers647
23 Apr 2011 19:54 #15397
by myers647
Replied by myers647 on topic Re: Lift topic for techies
eyup mate i no this isnt a reply to youyr question but i need to know wether you have had to fit extended brake lines when you put the 2'' lift springsd on.
i got a 2'' lift kit last week but havnt fitted it yet i dont want to buy brake lines if i dont need them.
thanks
thanks
Time to create page: 0.160 seconds
