sj free wheeling hubs onto a jimny
19 Nov 2009 15:57 #1488 by Garry
dam martin! you the man!!!!!
ill be ordering all 3 when my pay is in the bank,
can you pm me prices please, id like the hub adaptors, bolts, steering damper brackets and 2 possibly 3 bolt on recovery points
19 Nov 2009 19:22 #1489 by mlines
Ok so I have been out spannering the prototpyes!
The SJ hubs fit fine, I just need to source 30mm bolts to put into the kit. I didn't have enough bolts to fit the hubs properly to my car so it was only a trial fit.
You will need
You MUST get the cone collars with the hubs, these come on the old bolts and can be prised off by opeing the slot with a screwdriver and then winding them off the thread.
Typically the SJ bolts are too short and the Jimny bolts are too long.
The steering damper kit test assembled on the bench
The damper attaches to the steering arm using U-bolts and bracket 1. I think we need to review the U-bolts as whilst those my engineer sent are probably up to the job they certainly do not look the part.
Bracket 2 bolts to the cross member.
And here it is fitted!
Now clearly you are interested in the prices. I have to source the bolts for the hubs, but the target price for the kit of rings and bolts is £25 plus p+p (it may be less if the bolts are dirt cheap)
The steering kit DOES NOT INCLUDE THE DAMPER. This is because you can get them really cheap on EBAY, just search for LANDROVE DISCOVERY SERIES 1 STEERING DAMPER. If you pay more than £20 for the damper then you have paid too much.
The target price for the damper brackets is (subject to finding a better U-bolt at the same price) £38 plus p+p
The rear recovery point is designed to fit the REAR only (a front one is in production) and is designed for STANDARD cars, hence the length in the arm to bring it below the plastic bumper. The price for this is set at £42 plus p+p, there is a lot of metal in these - its 10mm thick plate.
I will be verifying the bolts and U-bolts tomorrow and then they will be in the shop
  • s2quattroturbo
19 Nov 2009 20:28 #1490 by s2quattroturbo
Replied by s2quattroturbo on topic Re:sj free wheeling hubs onto a jimny
excellent looking kit, if you have trouble getting the bolts let me know, i have a good place for getting them cheap.
20 Nov 2009 11:55 #1491 by mlines
The adaptors and brackets are now in the store to pre-order.
The recovery bracket will follow soon
21 Nov 2009 13:50 #1494 by Garry
i tried to pre order the hub adaptors and steering damper, the order button didnt do anything, ill try again in a few days
21 Nov 2009 14:17 #1495 by mlines
Fixed! - bit of finger trouble on my behalf. Estimate delivery is currently end of 1st week in December
Time to create page: 0.267 seconds
