sj free wheeling hubs onto a jimny
- Garry
18 Nov 2009 20:07 #1479
by Garry
sj free wheeling hubs onto a jimny was created by Garry
as title, ive got a pair i want to fit to my jimny to get rid of the dodgy vacume hubs.
what size spacers do i need to fit them, ive been told 5mm by someone and 7mm by someone else
im confused now
im confused now
18 Nov 2009 20:28 #1480
Replied by mlines on topic Re:sj free wheeling hubs onto a jimny
Watch this space - tomorrow (Thursday)!!!
- Garry
18 Nov 2009 20:31 #1481
by Garry
Replied by Garry on topic Re:sj free wheeling hubs onto a jimny
thanks Martin, will be checking back tomorrow, just browsing through your site, been a few new topics since my last visit
- Garry
18 Nov 2009 20:35 #1482
by Garry
ohh and i forgot, do i need longer hub bolts, and ifso where do i get them?
thanks for taking the time to help Martin
19 Nov 2009 14:10 #1486
by kirkynut
Replied by kirkynut on topic Re:sj free wheeling hubs onto a jimny
No spacers necessary, just take off your wheel bearing nut using the correct tool, sold by Martin and Bits4Vits, stick the nut in a vice and cut it down by the required 5-7mm or further, it matters not, then do it back up to the required torque and fit a manual freewheeling hub off an SJ or Vitara.
No new parts needed, no cost.
I was given cut down nuts with some fixed hubs I bought when I bought my Jimny direct from KAP as I knew the problems with the vacuum operated ones. I have a set of freewheelers to take off our SJ410 before it gets sold and will put them on the Jimny.
19 Nov 2009 14:25 #1487
Alternatively to cutting it up you could fit a set of these!!
Bigjimny SJ hub adaptors!!
New today, these are the protoypes hence they are blue and not plated, the real ones will be plated.
I will post "fitted" pictures later, this will also let me sort out the bolts required.
And while you are looking for Christmas gifts how about, bolt on steering damper brackets....
Or a bolt on rear recovery point.....
As you can see by the fact that it is plated, this one has emerged from prototyping. All soon to be in a shop near you!
More details later on once I have done a bit of spannering.
Time to create page: 0.591 seconds
