Jimny front discs
  • kangooman
03 Apr 2011 13:01 #14401 by kangooman
Jimny front discs was created by kangooman
Hi
Could you tell me if there are different discs for the later Jimny (mines a 2007).
I went to replace the discs and pads today, but the discs would not go over the hub.
I've looked online to see if there different sizes but as far as I can see all Jimnys have the same size discs.
The centre hole in the new discs are 107mm, but like a donkey I didn't measure the old disc center hole.
I've cleaned all the hub etc, but no way will the new disc fit.
Cheers
Richard
  • adamjimny
03 Apr 2011 13:34 #14403 by adamjimny
Replied by adamjimny on topic Re: Jimny front discs
im sure they are all the same.
the disc is a tight fit i used a rubber mallet to gently tap it into place so it sits flush
  • kangooman
03 Apr 2011 13:38 #14404 by kangooman
Replied by kangooman on topic Re: Jimny front discs
I can confirm that the center hole in my disc is 108.5mm hence the new discs wont fit being 107mm.
it was bugging me so much I just went out and whipped the disc off again :P
I bet I'll have to fit genuine discs knowing my luck :evil:
Cheers
Richard
03 Apr 2011 13:40 #14406 by mlines
Replied by mlines on topic Re: Jimny front discs
They are different sizes.
Early Jimny discs up to VIN 203804 have 107mm diameter holes.
From VIN 203804 onwards the holes are 108.3 mm
Therefore a new series disc will fit an old car, but an old series disc will not fit a new car.
  • adamjimny
03 Apr 2011 13:48 #14407 by adamjimny
learn something new everyday
but that sucks for you
  • kangooman
03 Apr 2011 13:48 #14408 by kangooman
Martin thanks for cofirming that I thought it was me going mad
Would you know if there is and aternative naufacture for these discs/ or will I have to use Genuine?
Cheers
Richard
Time to create page: 0.166 seconds
