bearing !!!!!!
- dc5
11 Oct 2009 16:39 #1341
by dc5
bearing !!!!!! was created by dc5
Hi guys, I`m a 4x4 noob and have just bought my 1999 jimny for going shooting on farmland.
I noticed a small amount of fluid on the road just beside the front left wheel
I know nothing about 4x4`s so I`m after a bit of help and advice.
I took a couple of pics and would like your help identifying the problem.
jase.
jase.
11 Oct 2009 16:56 #1342
Replied by mlines on topic Re:bearing !!!!!!
Its either the Kingpin Bearings or the wheel bearing.
Jack the car up and rock the wheel. If it rocks with your hands top and bottom it tends to be the Kingpin bearings. If it rocks with your hands on either side then it tends to be the wheel bearings. Get an assistant to press the brakes. If it still rocks then its the Kingpin bearings, if the rocking stops then its the wheel bearings
My money would be on the Kingpin bearings
- dc5
11 Oct 2009 17:08 #1343
by dc5
Replied by dc5 on topic Re:bearing !!!!!!
Thanks martin, I have a mechanic going to look at It next week.
What sort of price would I be looking at for both parts?
jase.
jase.
11 Oct 2009 17:13 #1344
Well there is this online shop I have found that sells the parts
Kingpin Bearings
Wheel Bearing
Kingpin Bearings
Wheel Bearing
- dc5
11 Oct 2009 17:15 #1345
by dc5
Will It still be ok to drive with this problem?
I bought some diff oil to keep It topped up.
jase.
jase.
11 Oct 2009 17:20 #1346
As with all leaks (including blood from your limbs) it always looks more severe than it really is. You will probably find the road is awash with oil but your diff actually takes very little to top it up.
The usual limitation is that you will quickly become scared of the severe steering wobble that will develop (particularly between 30mph and 40 mph)
