spring spacers?
  • chrisjimny
04 Oct 2009 19:21 #1335 by chrisjimny
spring spacers? was created by chrisjimny
Hi, could someone help me out please?
Im after a small lift for my (mainly road going)jimny, which has 215/75/15 Grabber AT2's fitted.
Im looking at spring spacers and the front shock extension bolts.
My question is, there are extension bolts available for the front, but what about the rear shocks?
Any advice or info on the matter would be gratefully appreciated
Cheers
Chris
  • chrisjimny
08 Nov 2009 14:12 #1436 by chrisjimny
Replied by chrisjimny on topic Re:spring spacers?
Thanks for the help B)
  • dirtydogzz
15 Nov 2009 13:24 #1462 by dirtydogzz
Replied by dirtydogzz on topic Re:spring spacers?
Hi,
I've just fitted Bits4Vits 1.25 spacers to my Jimny with the standard shocks,and it rides ok on the road & green lanes.
A little tip though, buy some spring compressers, it makes the job a lot easier!
Baz
  • chrisjimny
15 Nov 2009 17:17 #1463 by chrisjimny
Thanks for that mate, is there any travel left in the shocks?
Have you fitted the shock spacers at all?
Mine is only used on farm fields and muddy tracks when off road, but the tyres hit up in the arches if I go over any big-ish bumps so I only need a small lift to help prevent it.
  • dirtydogzz
16 Nov 2009 06:55 - 16 Nov 2009 10:00 #1465 by dirtydogzz
hi,
no shock spacers,the lift is only about 1 inch high so shocks are working ok.
if your not happy with the ride fit shock spacers later.
baz
Last edit: 16 Nov 2009 10:00 by dirtydogzz.
  • chrisjimny
16 Nov 2009 17:00 #1468 by chrisjimny
Thanks again for the reply mate, will give them a go
Time to create page: 0.170 seconds
