Dash removal
  • Nelson83
30 Mar 2011 09:46 #14282 by Nelson83
Replied by Nelson83 on topic Re: Dash removal
Its something that was bugging me for a while - the light kept flickering and then finally blew, and it then drove me nuts not having the illumination behind the vent controls. I used the 1.2W ones from halfrauds and they had them in my local ones with a green bulb, so being the tight arse i am, i carefully peeled the rubber cover off the old one and then stripped my tiltometer down and stuck it on the bulb in that. The colour match between all my illumination on the dash is now pretty much spot on.
  • wykiw
25 Jun 2011 20:21 #18261 by wykiw
Replied by wykiw on topic Re: Dash removal
I want to install a GPS/Radio system in my Jimny but i find it difficult to remove the dash to get to the radio. please email me the guide as well.
  • jimny5
25 Jun 2011 20:41 #18263 by jimny5
Replied by jimny5 on topic Re: Dash removal
its quite easy,
to replace bulb for heaters you can get to it by removing radio and the bulb is just above that,no need for dash removal,
to remove radio center trim 1 screw at top in middle two at the bottom and two or three in behind ash tray ,trim and radio should just kinda fall out with abit of persistence.
26 Jun 2011 02:16 #18271 by Halford
Replied by Halford on topic Re: Dash removal
great guide ;)
for anyone with a newer style dash, there's a good guide for removing the centre console trim here Installing an USB/SD/MP3/Aux-in adapter
  • slavya
01 Jun 2012 07:26 #41540 by slavya
Replied by slavya on topic Re: Dash removal
Would you so kind and send the guide to me.
Thanks in advance.
  • dirtydogz
01 Jun 2012 10:12 - 01 Jun 2012 10:17 #41554 by dirtydogz
Replied by dirtydogz on topic Re: Dash removal
The guide is in information at the top of the page, there are lots of tips on how to repair things on your jimny in there. ;)
www.bigjimny.com/images/documents/changing_the_heater_bulb.pdf
Last edit: 01 Jun 2012 10:17 by dirtydogz.
