Dash removal
  • Nelson83
11 Mar 2011 16:14 #13070 by Nelson83
Dash removal was created by Nelson83
Has anybody already removed the dash from their truck? The illumination of the heater controls has finally given up the ghost - my usually trick on boshing the top of the dash to get it to come on has stopped working. :-( so ive decided that i need to investigate and have a poke around behind the scenes!!!
Is there a diagram in the parts manual that shows how its put together - surely it comes apart some how - i can see how at the moment
  • little monster
11 Mar 2011 17:09 #13083 by little monster
Replied by little monster on topic Re: Dash removal
Undo all the screws and pull towards you, no need to take the steering column to bits, a t5 bulb will be required
  • Nelson83
11 Mar 2011 17:30 #13086 by Nelson83
Replied by Nelson83 on topic Re: Dash removal
ive found the screws under the dials console - are there/ where are any more located?
  • wildfire
12 Mar 2011 09:22 #13154 by wildfire
Replied by wildfire on topic Re: Dash removal
If i remember correctly there under some in the glove box and in the ash try area.
  • Nelson83
13 Mar 2011 16:02 #13249 by Nelson83
Managed to solve the problem and replace the bulb that was causing the problem - even manged to create a guide which ive emailed to martin B)
  • ooky_123
30 Mar 2011 09:14 #14281 by ooky_123
Replied by ooky_123 on topic Re: Dash removal
Great Guide, followed it and did mine in about 15 minutes.
Incidently, there are 2 bulb options that will fit, I went to halfords and they stock a 1.2 watt bulb and a 3.2 watt bulb.
I bought both and tried both ... the 1.2 watt one is ok, but the extremeties of the displays are a little dim, the 3.2 is superb.. but you donot get the green cover to go on it, so the display is now white as opposed to the origional green.
Incidently, you can also get at the bulb carrier if you remove the glove box (but only if you know where your going and know how to remove the grey carrier. it involves hanging out teh passenger door and using your left hand to feel inside the dash (you do need to remove the radio though !!)
Your way if definatly easier I do have to add :)
Time to create page: 0.178 seconds
