Stiff accelerator pedal
- coptleigh
10 Mar 2011 15:43 #12983
by coptleigh
Stiff accelerator pedal was created by coptleigh
This has got worse over the last few weeks, so checked it out and its not the cable, from what i can see its the actual pedal itself, the pedal bar that runs through the mounting brackets is rubbing metal on metal!!!
Does this make sense????
Anyway, this is whats causing the friction, is there suppose to be some sort of barrier between them or is it down to being twisted or something.
finally is there a remedy?, can it be changed for another one from another Suzuki??
Cheers
Alan
Cheers
Alan
- andyw
10 Mar 2011 17:35 #12987
by andyw
Replied by andyw on topic Re: Stiff accelerator pedal
Try WD40 on it, clean any dust mud out of it, any rust got in there from water getting in there?
Andy
Andy
- coptleigh
10 Mar 2011 18:01 - 10 Mar 2011 18:02 #12988
by coptleigh
Replied by coptleigh on topic Re: Stiff accelerator pedal
Tried that and grease, no rust from water ,,,, it actually looks like that its grinding, and wearing grooves in the shaft ,,,,,, from the two plates it goes through!! is there some sort of bush missing that keeps metal away from metal?? or is it just a bad design
Alan
Alan
Last edit: 10 Mar 2011 18:02 by coptleigh.
10 Mar 2011 18:17 - 10 Mar 2011 18:18 #12989
Replied by mlines on topic Re: Stiff accelerator pedal
Last edit: 10 Mar 2011 18:18 by mlines.
- coptleigh
10 Mar 2011 18:34 #12992
by coptleigh
Thanks for that Martin, it shows no kind of separator between the shaft and the two locating holes, wonder if its been twisted/bent by me somehow???
Any advice, or is it a trip to the breakers to see if I can find a one, or someone on here got one for sale??
Cheers
Alan
Cheers
Alan
- Keefe
10 Mar 2011 18:53 #12997
by Keefe
Replied by Keefe on topic Re: Stiff accelerator pedal
I would have thought that bit would be as cheap as chips as it's only the throttle pedal bit. It's separate from the brake and clutch mount.
Loads being broke on Ebay if no one on here has one.
