are they all the same
  • vitara_mad
07 Mar 2011 14:02 #12765 by vitara_mad
are they all the same was created by vitara_mad
are all jimny sohc engines the same ???
thinking of taking one out of a soft top w reg & fitting it into a hard top w reg
they look same but just thought i would check first to make sure there is not some slight differance that will cause it not to run in the hard top jimny
thanks
07 Mar 2011 14:05 #12766 by mlines
Replied by mlines on topic Re: are they all the same
I believe that in all the major components they are the same. There may be some minor component changes here and there but in the major physical components they are identical.
07 Mar 2011 17:13 #12775 by facade
Replied by facade on topic Re: are they all the same
There have been some posts about missing sensors, the hard top will be a Japanese built car, the soft top Spanish, this might make a difference.
  • vitara_mad
07 Mar 2011 20:20 #12781 by vitara_mad
Replied by vitara_mad on topic Re: are they all the same
so is there anything i need to look for to make sure there the same & have same sensors & whatknott
07 Mar 2011 21:41 #12794 by facade
Look at the sensors fitted to the hard top cam, crank or both together, and make sure the soft top has the same.
I'm sure I read posts about having to change the oil pump housing between engines to solve this problem.
  • vitara_mad
07 Mar 2011 22:34 #12799 by vitara_mad
thanks for the tips will have a look & hope they are same if not then it wont be getting swapped over as dont want to be changing engine parts about.
Time to create page: 0.361 seconds
