Tranfer case conversion kit's
  • Monkey
06 Mar 2011 12:16 #12656 by Monkey
Tranfer case conversion kit's was created by Monkey
Hi guy's,
My self and some other Australian jimny owner's, are wondering about these transfer conversion kits from off-road amoury and D&G tuning, what i would like to know if these kits suit the late model VVT jimny as they have different gear box, input shaft, transfer case and drive shaft's to the early model jimny's.
Why we want them is because then we could put a sierra/samurai t-case in for more gearing options.
Has anyone used one of these kits and done the conversion in a late model VVT jimny using one those kits?
Thanks in advance.
Andy
06 Mar 2011 12:25 #12657 by mlines
Yes you can fit these kits.
You have to do a quick re-wire to keep the flashing lights on the dashboard happy.
I know the UK VVTs to at least 2007 have the hole in the transmission tunnel required for the transfer lever blanked off so you can unbolt the plate and you have the correct hole.
You would probably want the console from an older Jimny to tidy up the edges of the hole neatly.
The following user(s) said Thank You: Monkey
  • Monkey
06 Mar 2011 12:30 #12659 by Monkey
Replied by Monkey on topic Re: Tranfer case conversion kit's
Ok thanks!
The plate covering plate is still there, but what about the jack shaft?and other mounting point?
do you have a link to the kit i will need?
06 Mar 2011 12:37 #12661 by mlines
Oops - yes - the intermediate or jack shaft doesn't fit either.
You need to do a "cut n shut" to get the Jack Shaft to fit. I know one member here has done this ok and a prop shaft specialist was happy to do the cut and weld.
  • darthloachie
06 Mar 2011 12:40 #12662 by darthloachie
  • Monkey
06 Mar 2011 12:42 #12663 by Monkey
Ok thanks so it looks like just the drive shafts need altering right?
