2nd battery
- glaggs
06 Mar 2008 13:15 - 06 Mar 2008 13:56 #11
by glaggs
2nd battery was created by glaggs
Hi,
in your list of mods you mention you plan to fit a second battery in the back of your Jimny because of lack of space under the bonnet. I have a second battery fitted under the bonnet. Its actually a Landrover Discovery battery so bigger than the Jimny one, but I made up a bracket and mounted it on the passeger side, just behind the washer bottle resevoir. There is jus enough room to get it in. Unfortunately I don't have any photo's but will try and send you some.
Last edit: 06 Mar 2008 13:56 by mlines.
06 Mar 2008 13:59 - 06 Mar 2008 14:30 #14
Replied by mlines on topic Re:2nd battery
Hi and welcome to "Big Jimny"
The large battery I have fouls the bonnet when mounted where the washer bottle is. I have move the washer bottle back and fitted the winch solenoids into place under the bonnet.
The battery has then gone into the boot with a long cable run (voltage drop
) to the front. But its very heavy duty cable so hopefully the losses are minimised.
Last edit: 06 Mar 2008 14:30 by mlines.
- BAZZOOK
09 Jul 2008 22:42 #64
by BAZZOOK
Replied by BAZZOOK on topic Re:2nd battery
some pics of my deep cycle battery. made up bracket from some angle. fitted solenoid on firewall along with solar regulater for solar panel which pumps out 74 watts. stops overcharging, regulates voltage to 14v and prevents discharge at night.
- BAZZOOK
09 Jul 2008 23:01 #65
by BAZZOOK
[img] [img]
10 Jul 2008 06:57 #67
First of all - welcome
Image attachment should work now. Otherwise you can email me pictures and I will put them in the main part of the website as a modification.
- BAZZOOK
10 Jul 2008 21:22 #72
by BAZZOOK
