rear bearing protection
  • tburt
05 Feb 2011 21:25 #11061 by tburt
Replied by tburt on topic Re: rear bearing protection
Attachment jimnyaxle014.jpg not found
grinded of bearing to allow me to pull of retainer and save it.
Attachment jimnyaxle021.jpg not found
retainer off and naked halk shaft
Attachment jimnyaxle023.jpg not found
this is where the new seal will sit.
  • vitara_mad
05 Feb 2011 21:27 #11062 by vitara_mad
Replied by vitara_mad on topic Re: rear bearing protection
sounds a realy good idea but i dont have use of a lathe so would have to try find some pipe the right size
  • tburt
05 Feb 2011 21:29 #11063 by tburt
Attachment jimnyaxle024.jpg not found
this is where the seal will sit on the backing plate
Attachment jimnyaxle026.jpg not found
peice made up to take new seal and its welded onto the backing plate
Attachment jimnyaxle027.jpg not found
backing plate with new seal into it.
  • tburt
05 Feb 2011 21:32 #11064 by tburt
Attachment jimnyaxle028.jpg not found
completed with new bearing and retainer pressed back on
Attachment jimnyaxle030.jpg not found
new seal from the outside
  • tburt
05 Feb 2011 21:36 #11065 by tburt
yea i got my mate to make it up for me and weld it on. you would have to get someone to lathe it up
maybe if some started to make alot of these they could just sell them and you would just have to weld it on or they could make up a plate that just has to be bolted on with the existing backing plates bolts
a kit could contain a seal the peice to bolt or weld on. just a idea to someone who have the time and gear to make a bit on extra money.
  • renard38
06 Feb 2011 09:06 #11074 by renard38
Replied by renard38 on topic Re: rear bearing protection
very intersting, but the new seal will be not grease, so it will be destroyed quick ???
Time to create page: 0.353 seconds
