Attempted to fit my rear Panhard Rod
04 Feb 2011 10:40 #10916 by Obarno
Don't know if its possible Martin but can you unbolt the bracket for the caliper and move it round one hole? Or if not would castor correction bushes in the rear arms move the caliper our of the way?
Just a couple of thoughts!
04 Feb 2011 11:01 #10917 by mlines
I wondered about the caliper but thought it would upset the Handbrake cable arrangement, if I go one way the cable will be pointing at the ground and the other way it would be straight up.
I was wondering about Castor Correction or corrected arms. However it is not completely clear in my mind which direction the axle will rotate/move.
I will look into it further
04 Feb 2011 19:41 #10959 by mlines
So what do you think?. The arc of the axle movement seems to point to the Panhard Rod Mount arc moving down to the left as the suspension compresses and up to the left as the suspension expands meaning that this is as close as they get (if my thoughts are correct).
04 Feb 2011 19:43 #10960 by mlines
P.S. Note that "Mr Angry" the Angle Grinder had to come out and teach the Panhard Bolt a lesson.
05 Feb 2011 10:17 #10990 by Obarno
I think your logic is right on the arc but to be sure - as sometimes off roading there are a lot of forces on components - would it be possible to cut the bottom off the bracket and move the bolt position higher? A possible downside though is that it is likely to make the car more 'twitchy' as ideally the panhard rod should be parallel to the axle, and also physically quite difficult to do!
Castor correction bushes would push the nose of the diff down and move the caliper slightly further forward.
  • paulnb57
05 Feb 2011 14:23 #11007 by paulnb57
Replied by paulnb57 on topic Re: Attempted to fit my rear Panhard Rod
Martin,
Why not cut the original Chassis mount off and fab a new one the moves the mounting a bit closer inboard? Looks like only about an inch inwards would do it and fabbing a bracket shouldn't be too much of a drama(??)
Paul
