Cylinder block measures....
05 Sep 2026 01:28 - 05 Sep 2026 01:28 #265199 by fordem
Replied by fordem on topic Cylinder block measures....
The manual service (this one piece was given to me by Suzuki repretsentative) only describes how the maximum amount of flatness to be corrected: 0,05mm!
I think this is a misinterpretation - the service manual does not say that 0.05mm is the maximum amount of distortion that can be corrected, but rather that distortion that exceeds 0.05mm needs to be corrected.
I agree that you cannot remove material willy-nilly from the deck, if you do you run the risk of the piston crowns being higher than the deck with potentially disastrous (piston/head/valve contact) results, which don't seem to have happened here, the other possible effects are the cam timing being retarded (overhead cam engines only), which is fairly easy to check and an increase in compression ratio, which would/should show in the compression numbers, which we have been told are "ok".
Last edit: 05 Sep 2026 01:28 by fordem. Reason: reword for clarity
The following user(s) said Thank You: NelsonB
05 Sep 2026 05:12 #265201 by Lambert
Replied by Lambert on topic Cylinder block measures....
Excessive fuel use and low power with spluttering running is very often associated with the primary catalytic converter having failed and the debris from that then blocking the secondary converter. If the symptoms only started after the engine was removed for the machining work it's entirely possible that taking it out disturbed the exhaust and hastened the demise of the catalytic element. It sounds coincidental to me, I'd not expect mating surface machining to cause your jimny to not run properly.
06 Sep 2026 01:16 #265204 by NelsonB
Replied by NelsonB on topic Cylinder block measures....
In fact, the engine was removed after an overheating failure with engine stalled. This shouldn't have happened, as the vehicle had recently undergone a major service, including the cooling system. Unfortunately, the engine was sent to the repair shop without prior testing of the sensors, and after reassembly, the scanner indicated and we replaced many sensors, including the pre- and post-cat. The catalytic converter itself was not serviced. After that, I went do a Suzuki oficial workshop that told me about the excess of flatness correction as a possible cause.
06 Sep 2026 02:28 #265205 by fordem
I'm going to assume that this translates into the engine overheated & seized.  In a situation like this, it would not be normal to check any sensors, if the engine has seized, it's a mechanical problem.
What was it the scanner indicated after reassembly and what sensors were replaced & why?
07 Oct 2026 15:08 #265361 by NelsonB
The scanner indicated first the pos cat sensor, and after this was replaced, the pre cat sensor, wich is also chenged (both) from a Bosch Universal model (it was needed to change some wiring in it).
08 Oct 2026 21:01 - 08 Oct 2026 21:02 #265366 by yakuza
Replied by yakuza on topic Cylinder block measures....
Clogged or broken catalytic converters can make the sensors send two kinds of fault codes, one is the insufficient functioning cat and the other is a faulty sensor code. Swapped the sensors on the Swift m13 a few times before swapping the cat Converter. Been nice ever since.
Last edit: 08 Oct 2026 21:02 by yakuza.
Time to create page: 0.247 seconds
