Cylinder block measures....
02 Sep 2026 18:23 #265183 by NelsonB
Hi everyone!
I am strugling for months with an engine JB43 rebuild with +0,50 original pistons.
The manual service (this one piece was given to me by Suzuki repretsentative) only describes how the maximum amount of flatness to be corrected: 0,05mm! He said Suzuki recomends to not accept more than this because integration of sensor signals could not work properly.
However, it did not inform the original size.
As the engine condtioning company did not measure it pre and pos service, I am in the dark and the Jimny is with high consumption and low power. We changed almost every sensor, and I know many other pieces could be involved, I just want to rule out this one.
Best Regards!
02 Sep 2026 18:48 #265184 by fordem
Replied by fordem on topic Cylinder block measures....
Which "original" measurements are you looking for?
The original bore diameter (which you can find in the owner's manual) would have been 78.0mm, this, by the way, is not something the company that reconditioned the engine would have been able to measure - if the engine need to be bored oversize, the bores would have been worn long before the block ever got to them.
03 Sep 2026 07:23 #265186 by Busta
Replied by Busta on topic Cylinder block measures....
That measurement is the flatness of the surface of the block, to ensure it seals correctly with the gasket and holds compression. It won't affect any sensors. A compression test will give you an indication if the gasket is sealing correctly.
The following user(s) said Thank You: NelsonB
03 Sep 2026 17:29 #265190 by Lambert
Replied by Lambert on topic Cylinder block measures....
I had the head skimmed on my last one and apparently they did 3 passes to get it flat, never did get a proper answer as to what the actual measurement of material removed was but whatever it was it never effected the running of the car.
04 Sep 2026 22:51 #265197 by NelsonB
Replied by NelsonB on topic Cylinder block measures....
I suppose that a measure of the block height, wich is not available in the service manual. The car mechanic performed compression test, he said it is ok. However, the fuel consumption increased nearly 40%, the power is reduced, and somotimes the car is sputtering.
04 Sep 2026 22:56 #265198 by NelsonB
the engine block and cylinder head was serviced.....in 2 different engine repair companies. It has anexpressive cost..... I am sending to another repair company, but without the original heigh, it is not possible to know if it surpass the service manual limit.....
Time to create page: 0.674 seconds
