rear indicator lights not working
3 months 3 weeks ago #264999
by brin
rear indicator lights not working was created by brin
i just aquire a 2012 jinmy 1.3 and the trader has left me with no rear indicators.
i checked the bulbs and they seem ok ,the flasher seems ok as the front indicators are working, the hazrard lights are working all ok , so not sure what to check next, is it likely the bulbs are faulty even tho the filament looks ok?
thanks i a
thanks i a
3 months 3 weeks ago #265000
by brin
Replied by brin on topic rear indicator lights not working
for i nterest
3 months 3 weeks ago #265001
by fordem
Replied by fordem on topic rear indicator lights not working
If you don't have the tools to test the bulbs, then replacing them, at least one, will be the least expensive way to find out.
3 months 3 weeks ago - 3 months 3 weeks ago #265002
Replied by yakuza on topic rear indicator lights not working
there are differences between markets and models wether the blinkers are down in the bumper or up on the C-pillar.
Do the other lights in the same lamp work? If your blinkers are placed down low, do the other lights in the same cluster work?
If not there might be a grounding problem for the cluster. Follow the wiring loom towards the chassi and see if there is proper connection to ground.
Also often the wiring for the trailer plug is done badly and can cause problems if it isnt one of the proper plug in loom type.
Last edit: 3 months 3 weeks ago by yakuza. Reason: typo
3 months 3 weeks ago #265005
by brin
i checked the rear lights and theyre not working either ,dunno where to look for connector plugs to check for earths ,i can check the bulbs with a meter next
- Thank you received: 2004
3 months 3 weeks ago #265006
Replied by Lambert on topic rear indicator lights not working
Normally the wires for the bumper pass through a grommet in the body accessed by removing the bumper and looking behind the rubber flap on the passenger side. Once in there it will be fairly obvious if someone has been in before you and butchered the loom for trailer lighting.
Time to create page: 0.112 seconds
